SIP re-INVITE Suppression Configuration
To enable SIP re-INVITE Suppression:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-interface
and press Enter.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
options—Set the options parameter by typing
options, a Space, the option-name
suppress-reinvite with a plus sign in front of it, and then press Enter.
ORACLE(sip-interface)# options +suppress-reinvite
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the SIP interface configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
