SIP Server Redundancy Configuration
To enable replace URI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
local-policy and press Enter to access the system-level configuration elements. The system prompt changes.
ORACLE(configure)# local-policy ORACLE(local-policy)#
Type
policy-attributes and press Enter. The system prompt changes.
ORACLE(local-policy)# policy-attributes ORACLE(local-policy-attributes)#
From this point, you can configure policy attributes for the local policy. To see all local policy attribute options, enter a ? at the system prompt.
action—Set this parameter to
replace-uri, which causes NAT rules such as realm prefixing to be overridden. The default value is
none. Valid values are:
none | replace-uri | redirect
The replace URI field allows you to indicate whether the local policy’s value is used to replace the Request-URI in outgoing requests. This boolean field can be set to either enabled or disabled.
