Configuring the SIP Configuration
To configure the SIP configuration:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-config and press Enter. The system prompt changes.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
From this point, you can configure SIP configuration parameters. To view all sip-config parameters, enter a ? at the system prompt.
inactive-dynamic-conn—Enter the time in seconds after which the
Oracle® Enterprise Session Border Controller tears down inactive dynamic TCP connections. Inactive is defined as not transporting any traffic. This protects against endpoints establishing TCP/TLS connections and then not sending messages. The default value is 32. The valid range is:
Minimum—0
Maximum—999999999
Setting this parameter to 0 disables this parameter.
Because the Oracle® Enterprise Session Border Controller first establishes a TCP connection, then the TLS connection it waits twice the value entered here after the initiation of a TLS connection before tearing down the connection.
After an endpoint establishes a TCP/TLS connection, it is supposed to keep the connection active by sending messages or by using the NAT interval configuration. Whenever a connection is torn down because of inactivity, a log at the level ERROR is generated.
