Stopping a Remote Packet Trace
You stop a remote packet trace by entering the appropriate ACLI command with these pieces of information:
- Network interface (name:subport ID combination)
- IP address to be traced
- (Optional) Local UDP/TCP port on which the Oracle® Enterprise Session Border Controller sends and receives traffic to be traced
- (Optional) Remote UDP/TCP port to which the Oracle® Enterprise Session Border Controller sends traffic, and from which it receives traffic to be traced
If the packet trace you want to stop has no entries for local and/or remote ports, then you do not have to specify them.
