SNMP Hardware Reporting
The Acme Packet 3900 platform relies on a specific set of MIB objects, in addition to the standard MIB objects.
The Acme Packet 3900 platform supports MIB objects for power supplies, fans, temperature sensors, system information, transcoding DSP(s), wancom ports, media ports, and the product OID. The Standard MIBs (such as MIB-2 objects) are supported.
The Acme Packet 3900 monitors the following environmental parameters by way of SNMP:
Updates to sysObjectID OID in the ap-products.mib.
- Updates the apNetNet 3000Series object to include the apNetNet 3900 object.
Updates to the entity OID in ap-entity-vendortype.mib.
- Updates the apevPowerSupply object to include the apevPowerSupply 500 W object.
