Endpoint Demotion Configuration on CAC Failures
To configure endpoint demotion on CAC failures:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
access-control
and press Enter.
ORACLE(session-router)# access-control ORACLE(access-control)#
If you are adding this feature to an existing configuration, then you will need to select the configuration you want to edit.
- cac-failure-threshold—Enter the number of CAC failures for any single endpoint that will demote it from the trusted queue to the untrusted queue.
- untrust-cac-failure-threshold—Enter the number of CAC failures for any single endpoint that will demote it from the untrusted queue to the denied queue.
- Save your work.
