SIP-H.323 IWF in Video Conferencing Applications
For video conferencing and other video applications, the Oracle® Enterprise Session Border Controller supports interworking between the H.323 Miscellaneous Commands videoFastUpdatePicture and the SIP INFO containing XML schema for Full Update. The noted H.323 message commands the video encoder to enter fast-update mode.
There is no configuration required for the interworking between these two messages to work.
