Trap Receiver Configuration
To configure trap receivers:
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal
Type
system and press Enter to access the system-level configuration elements.
ACMEPACKET(configure)# system
Type
trap-receiver and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ACMEPACKET(system)# trap-receiver ACMEPACKET(trap-receiver)#
From this point, you can set trap receivers.
The following is an example of a trap receiver configuration. Parameters not described in this section are omitted below.
trap-receiver ip-address 10.0.1.42:162 filter-level All community-name public user-list jsmith,carolM,gcather
- ip-address—Set the IPv4 address of an authorized NMS. This parameter is the IPv4 address of an NMS where traps are sent. If you do not specify a port number, the default SNMP trap port of 162 will be used.
filter-level—Set the filter level threshold that indicates the severity level at which a trap to be sent to this particular trap receiver. The default for this parameter is
critical.
Example: A trap with a severity level of Critical is generated, the SNMP agent will only send this trap to NMSs that are configured in a trap-receiver element and have a filter-level parameter of Critical.
The following table maps Syslog and SNMP alarms to trap receiver filter levels.
Filter Level Syslog Severity Level (SNMP) Alarm Severity Level Critical Emergency (1) Critical (2)
Emergency Critical
Major Emergency (1) Critical (2)
Major (3)
Emergency Critical
Major
Minor Emergency (1) Critical (2)
Major (3)
Minor (4)
Emergency Critical
Major
Minor
All Emergency (1) Critical (2)
Major (3)
Minor (4)
Warning (5)
Notice (6)
Info (7)
Trace (8)
Debug (9)
Emergency Critical
Major
Minor
Warning
When configuring the trap-receiver element for use with the Element Management System (EMS), Oracle recommends that you set the filter-level parameter to All for that configuration element that includes EMS servers.
- community-name—Set the community name to which this trap receiver belongs. This community must be defined in the SNMP community element.
user-list—For SNMPv3, specify a list of users that have authorized permissions to receive secure traps. Enter the user names as comma-separated values. For example:
ACMEPACKET(trap-receiver)# user-list jsmith,carolm,glather
If instances of snmp-user-entry are configured, but no users are listed under user-list, a warning message is sent during a verify-config execution.
