PreviousNextJavaScript must be enabled to correctly display this content
Communications Monitor Configuration
Communications Monitor configuration consists of the following steps.
Configuration of one or more
Oracle® Enterprise Session Border Controller/OCOM exporter/collector pairs.
Configuration of the
-config object, which defines common operations across all interfaces, is not required. Default values can be retained to enable standard service.
Optional assignment of a TLS profile to an exporter/collector pair.
The OCOM Probe communicates over the media interface for signaling and Quality of Service (QoS) statistics using IPFIX. QoS reporting is done via Call Detail Records (CDR) (accounting).
