Configure the Acme Packet 3900 Physical Interface
Decide the number and type of physical interfaces that you need.
Determine the slot and port numbering that you need to enter for the each physical interface. See the port numbering table.
If you are configuring High Availability (HA), refer to the HA documentation and follow the instructions for setting special parameters in the physical interface configuration.
