ACLI Registration Caching Configuration Example
In the following example, the H.323 gatekeeper interface (h323-stack) is private and the gateway interface (h323-stack) is public.
h323-config state enabled log-level DEBUG response-tmo 4 connect-tmo 32 h323-stack name private state disabled realm-id private assoc-stack public local-ip 192.168.200.99 max-calls 200 max-channels 4 registration-ttl 120 terminal-alias prefixes ras-port 1719 auto-gk-discovery disabled multicast 0.0.0.0:0 gatekeeper 0.0.0.0:0 gk-identifier q931-port 1720 alternate-transport q931-max-calls 200 h245-tunneling disabled fs-in-first-msg disabled call-start-fast disabled call-start-slow disabled media-profiles process-registration enabled anonymous-connection disabled proxy-mode filename h323-stack name public state enabled isgateway enabled realm-id public assoc-stack private local-ip 192.168.1.99 max-calls 200 max-channels 2 registration-ttl 120 terminal-alias prefixes ras-port 1719 auto-gk-discovery disabled multicast 0.0.0.0:0 gatekeeper 192.168.1.50:1719 gk-identifier gk-public.acme.com q931-port 1720 alternate-transport q931-max-calls 200 h245-tunneling disabled fs-in-first-msg disabled call-start-fast disabled call-start-slow disabled media-profiles process-registration disabled anonymous-connection disabled proxy-mode filename
