About RAS Message Treatment
When you enabled the H.323 Registration Proxy, the Oracle® Enterprise Session Border Controller modifies and deletes certain fields as outlines in the table below. The Oracle® Enterprise Session Border Controller sends on any fields that are not listed in this table without modifying or deleting them.
Although the Oracle® Enterprise Session Border Controller forwards a field, it does not always support the feature related to that field.| Field Name | Message | Deleted | Modified | Value Used in Modification |
| alternateEndpoints | RRQ, URQ, ACF | X | ||
| alternateGatekeeper | RCF, URQ | X | ||
| altGKInfo | RRJ, URJ, DRJ | X | ||
| alternateTransportAddresses | RRQ, ARQ, ACF | X | ||
| callModel | ARQ | X | direct | |
| ACF | X | gatekeeperRouted | ||
| callSignalAddress | RRQ | X | Mapped virtual CSA allocated by the system for registering the endpoint. | |
| RCF, ARJ | X | CSA of gatekeeper stack | ||
| URQ | X | If URQ is from an endpoint, endpoint’s mapped virtual CSA. If URQ is from a gatekeeper, real CSA of endpoint. | ||
| destCallSignalAddress | ARQ, ACF | X | ||
| destinationInfo.transportID | ARQ, ACF | X | ||
| destExtraCallInfo.trasnportID | ARQ, ACF | X | ||
| discoveryComplete | RRQ | X | TRUE | |
| endpointAlias.trasnportID | URQ | X | ||
| endpointAliasPattern.Wwildcard.transportID | URQ | |||
| featureServerAlias.trasnportID | RCF | X | ||
| gatekeeperIdentifier | RRQ | X | Gatekeeper identifier of the gateway stack, either configured in the H.323 gateway stack or discovered dynamically. | |
| maintainConnection | RRQ, RCF | X | FALSE | |
| mutlipleCall | RRQ, RCF | X | FALSE | |
| preGrantedARQ.alternateTransportAddresses | RCF | X | ||
| preGrantedARQ.useSpecifiedTransport | RCF | X | ||
| rasAddress | RRQ | X | Mapped virtual RAS address allocated by the system for registering endpoint | |
| remoteExtentsionAddress.trasnportID | ARQ, ACF | X | ||
| srcCallSignalAddress | ARQ | X | ||
| srcInfo.transportID | ARQ | X | ||
| supportedH248Packages | RRQ | X | ||
| supportsAltGK | RRQ | X | ||
| supportedPrefixes.prefic.transportID | RCF, URQ | X | ||
| terminalAlias.transportID | RRQ | X | ||
| terminalAliasPattern.wilcard.transportID | RRQ | X | ||
| willRespondToIIRR | RCF, ACF | X | ||
| willSupplyUUIEs | RRQ, ARQ | |||
| uuiesRequested
setup callProceeding connect alerting information releaseComplete facility progress empty ..., status statusInquiry setupAcknowledge notify |
ACF | X
X X X X X X X X X X X X |
FALSE
FALSE FALSE FALSE FALSE FALSE FALSE FALSE FALSE FALSE FALSE FALSE FALSE |
