SDP Anonymization Configuration
To enable SDP anonymization:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter.
ORACLE(configure)# media-manager
Type
media-manager
again to access the media manager configuration, and press Enter.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
anonymous-sdp—Set this parameter to enabled to use the SDP anonymization feature. When you leave this parameter empty the feature is turned off. The default value is
disabled. The valid values are:
enabled | disabled
- Save and activate your configuration.
