Timezones
The timezone on the Oracle® Enterprise Session Border Controller must be set manually via the ACLI using one of two methods:
- using the timezone-set command at the root prompt. This commands starts a timezone wizard that allows you to answer prompts specifically related to timezone settings. You can set your timezone location and the wizard automatically sets the daylight savings time for the location you select.
- at the path system->timezone. This parameter allows you to create a timezone name and apply specific instructions for daylight savings time (DST) and specify the number of minutes from Coordinated Universal Time (UTC). If you initiated the timezone-set wizard previous to accessing this parameter, the settings for system->timezone are already populated. You can change them if required.
It is recommended you set the timezone after first boot of the system.
