Media Setup & Playback
For each session requiring media playback, the Oracle® Enterprise Session Border Controller sets up media that supports standard RTP parameters. From the original media (if present), the
Oracle® Enterprise Session Border Controller preserves the synchronization source (SSRC), timestamp, and sequence number.
For all playback options besides playback-on-header, the playback duration is continuous, meaning that the media file loops if it fails to cover the entire playback period.
The playback duration for the playback on header scenario changes according to the settings in the P-Acme-Playback header. This header contains a duration=<ms-value|once|continuous> value, so you can customize the playback duration.
  • Continuous—Media playback continues until the point at which the playback scenario defines its stop; media file loops if it fails to cover the entire playback duration.
  • Once—The file plays until either the playback scenario defines its stop or until the media file runs out.
  • Ms-value—Playback continues for a specific duration (in milliseconds) and will loop if necessary.
Once playback is in progress, the Oracle® Enterprise Session Border Controller mutes the session in the playback direction so that only the playback media can be heard.
