Importing a Certificate Using FTP
Copy the certificate to the
/optdirectory of the Oracle® Enterprise Session Border Controller using SFTP. -
Import the certificate with the
import-certificate command.
Use the following syntax:
import-certificate [try-all|pkcs7|x509] [certificate name] [filename]
Use the value of the name parameter from the previously configured certificate-record configuration element for the certificate name argument.
ORACLE# import-certificate x509 acme certificate.pem Certificate imported successfully.... WARNING: Configuration changed, run "save-config" command. ORACLE#
Save the configuration.
ORACLE# save-config -
Activate the configurations.
ORACLE# activate-config - Reboot the system.
