Creating Steering Pools for Multiple Interface Realms
To configure steering pools for multi-interface realms:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-manager path.
ORACLE(configure)# media-manager
Type
steering-pool and press Enter. The system prompt changes.
ORACLE(media-manager)# steering-pool ORACLE(steering-pool)#
From this point, you can configure steering pools which collectively bridge the multiple network interfaces they are connected to.
ip-address—Enter the IP address of the first steering pool on the first network interface.
This IP address must correspond to an IP address within the subnet of a network interface you have already configured.
This IP can not exist on a network interface other than the one you configure in the network-interface parameter.
start-port—Enter the beginning port number of the port range for this steering pool. The default is
0. The valid range is:
Minimum—0
Maximum—65535
end-port—Enter the ending port number of the port range for this steering pool. The default is
Minimum—0
Maximum—65535
- realm-id—Enter the name of the realm which this steering pool directs its media traffic toward.
- network-interface—Enter the name of the network interface you want this steering pool to direct its media toward. This parameter will match a name parameter in the network-interface configuration element. If you do not configure this parameter, you can only assign a realm to a single network interface, as the behavior was in all Oracle® Enterprise Session Border Controller Software releases pre- 2.1.
- Create additional steering pools on this and on other network interfaces as needed. Remember to type done when you are finished configuring each new steering pool.
