PreviousNextJavaScript must be enabled to correctly display this content
TCP/FIN Generation Configuration
Use the following procedure to enable a TCP/FIN exchange between the
Oracle® Enterprise Session Border Controller and an Avaya user agent in the event of failure of an Avaya Session Manager.
send-tcp-fin—Set this parameter to enabled to generate a TCP/FIN exchange in response to the failure of this Avaya Session Manager. By default, this parameter is disabled.
