Example SPL Options
The following are examples of the Universal Call Identifier SPL.
Example 1
UCID-App-ID=0023,replace-ucid,convert-to=Avaya
This creates a User-to-User header based on a node ID of 23. Any value on the ingress side is replaced with the newly generated value. Removes all Cisco-GUID and Cisco-GUCID headers from egress messages.
Example 2
GUID-Node-ID=0x124578,convert-to=Guid
This creates a Cisco-GUID header if one does not exist in the ingress request. Removes all User-to-User and Cisco-GUCID headers from egress messages.
