PreviousNextJavaScript must be enabled to correctly display this content
Session Contraints Configuration
You enabled use of session constraints for nested realms across the entire system by setting the
nested-realms-stats parameter in the session router configuration to
enabled.
In Superuser mode, type
configure terminal and press Enter.
nested-realms-stats—Change this parameter from
disabled (default) to
enabled if you want the
Oracle® Enterprise Session Border Controller to apply session constraints across all nested realms (realms that are children to other realms)
