Rejected Messages Monitoring
Whitelists, when configured on the Oracle® Enterprise Session Border Controller, control whether or not the Oracle® Enterprise Session Border Controller allows unknown headers and URI parameters to be accepted in incoming request and response traffic. When the Oracle® Enterprise Session Border Controller rejects messages according to the whitelist, the rejected messages are logged to a file called “matched.log” if logging is set to enabled. You can open and view the log when required to view the rejected messages.
In addition to the rejected messages being logged to the “matched.log” file, the rejected messages are also sent through a burst counter that keeps track of the amount of messages rejected. You can enter the show sipd to display the number of rejected messages. The counter is titled Rejected Message.
