Acme Packet Codec and Transcoding MIB (ap-codec.mib)
The following table describes the SNMP GET query names for the Oracle Codec and Transcoding MIB (ap-codec.mib).
| SNMP GET Query Name | Object Identifier Name: Number | Description |
| Object Identifier Name: apCodecMIBObjects (1.3.6.1.4.1.9148.3.7.1) | ||
| Object Identifier Name: apCodecRealmStatsTable (1.3.6.1.4.1.9148.3.7.1.1) | ||
| Object Identifier Name: apCodecRealmStatsEntry (1.3.6.1.4.1.9148.3.7.1.1.1) | ||
| apCodecRealmCountOther | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.1 |
Count of the SDP media streams received in the realm which negotiated to a codec not defined in this table. |
| apCodecRealmCountPCMU | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.2 |
Count of SDP media streams received in the realm which negotiated to the PCMU codec. |
| apCodecRealmCountPCMA | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.3 |
Count of SDP media streams received in the realm which negotiated to the PCMA codec. |
| apCodecRealmCountG722 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.4 |
Count of SDP media streams received in the realm which negotiated to the G722 codec. |
| apCodecRealmCountG723 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.5 |
Count of SDP media streams received in the realm which negotiated to the G723 codec. |
| apCodecRealmCountG726-16 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.6 |
Count of SDP media streams received in the realm which negotiated to the G726-16 codec. |
| apCodecRealmCountG726-24 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.7 |
Count of SDP media streams received in the realm which negotiated to the G726-24 codec. |
| apCodecRealmCountG726-32 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.8 |
Count of SDP media streams received in the realm which negotiated to the G726-32 codec. |
| apCodecRealmCountG726-40 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.9 |
Count of SDP media streams received in the realm which negotiated to the G726-40 codec. |
| apCodecRealmCountG728 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.10 |
Count of SDP media streams received in the realm which negotiated to the G728 codec. |
| apCodecRealmCountG729 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.11 |
Count of SDP media streams received in the realm which negotiated to the G729 codec. |
| apCodecRealmCountGSM | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.12 |
Count of SDP media streams received in the realm which negotiated to the GSM codec. |
| apCodecRealmCountILBC | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.13 |
Count of SDP media streams received in the realm which negotiated to the iLBC codec. |
| apCodecRealmCountAMR | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.14 |
Count of SDP media streams received in the realm which negotiated to the AMR codec. |
| apCodecRealmCountEVRC | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.15 |
Count of SDP media streams received in the realm which negotiated to the EVRC codec. |
| apCodecRealmCountH261 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.16 |
Count of SDP media streams received in the realm which negotiated to the H261 codec. |
| apCodecRealmCountH263 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.17 |
Count of SDP media streams received in the realm which negotiated to the H.263 codec. |
| apCodecRealmCountT38 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.18 |
Count of SDP media streams received in the realm which negotiated to the T.38 codec. |
| apCodecRealmCountAMRWB | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.19 |
Count of SDP media streams received in the realm which negotiated to the AMR-WB codec. |
| apCodecRealmCountEVRC0 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.20 |
Count of SDP media streams received in the realm which negotiated to the EVRC0 codec. |
| apCodecRealmCountEVRC1 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.21 |
Count of SDP media streams received in the realm which negotiated to the EVRC1 codec. |
| apCodecRealmCountEVRCB | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.22 |
Count of SDP media streams received in the realm which negotiated to the EVRCB codec. |
| apCodecRealmCountEVRCB0 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.23 |
Count of SDP media streams received in the realm which negotiated to the EVRCB0 codec. |
| apCodecRealmCountEVRCB1 | apCopdecRealmStatsEntry
1.3.6.1.4.1.9148.3.7.1.1.1.24 |
Count of SDP media streams received in the realm which negotiated to the EVRCB1 codec. |
| Object Identifier Name: apTranscodingMIBObjects (1.3.6.1.4.1.9148.3.7.2) | ||
| Object Identifier Name: apCodecTranscodingRealmStatsTable (1.3.6.1.4.1.9148.3.7.2.1) | ||
| Object Identifier Name: apTranscodingRealmStatsEntry (1.3.6.1.4.1.9148.3.7.2.1.1) | ||
| apCodecRealmSessionsTransparent | apCodecTranscodingRealmStatsEntry:
1.3.6.1.4.1.9148.3.7.2.1.1.1 |
Number of sessions in the realm that did not use any DSP resources for transcoding or transrating. |
| apCodecRealmSessionsTransrated | apCodecTranscodingRealmStatsEntry:
1.3.6.1.4.1.9148.3.7.2.1.1.2 |
Number of sessions in the realm that had a common codec but used DSP resources to modify packetization rate. |
| apCodecRealmSessionsTranscoded | apCodecTranscodingRealmStatsEntry:
1.3.6.1.4.1.9148.3.7.2.1.1.3 |
Number of sessions in the realm that had used DSP resources to transcode between codecs. |
| Object Identifier Name: apSysMgmtMIBSessionObjects (1.3.6.1.4.1.9148.3.2.1.2) | ||
| Object Identifier Name: apSigRealmStatsTable (1.3.6.1.4.1.9148.3.2.1.2.4) | ||
| Object Identifier Name: apSigRealmStatsEntry (1.3.6.1.4.1.9148.3.2.1.2.4.1) | ||
| apSigRealmStatsRealmName | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.2 |
Nmae of the realm the following for which the following statistics are being calculated. |
| apSigRealmStatsCurrentActiveSessionsInbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.3 |
Number of current active inbouind sessions. |
| apSigRealmStatsCurrentSessionRateInbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.4 |
Current inbound session rate in CPS. |
| apSigRealmStatsCurrentActiveSessionsOutbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.5 |
Number of current active outbound sessions. |
| apSigRealmStatsCurrentSessionRateOutbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.6 |
Current outbound session rate in CPS. |
| apSigRealmStatsTotalSessionsInbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.7 |
Total number of inbound sessions. |
| apSigRealmStatsTotalSessionsNotAdmittedInbouind | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.8 |
Total number of inbound sessions rejected due to insufficient bandwidth. |
| apSigRealmStatsPeriodHighInbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.9 |
Highest number of concurrent inbound sessions during the period. |
| apSigRealmStatsAverageRateInbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.10 |
Average rate of inbound sessions during the period in CPS. |
| apSigRealmStatsTotalSessionsOutbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.11 |
Total number of outbound sessions. |
| apSigRealmStatsTotalSessionsNotAdmittedOutbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.12 |
Total number of outbound sessions rejected due to insufficient bandwidth. |
| apSigRealmStatsPeriodHighOutbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.13 |
Highest number of concurrent outbound sessions during the period. |
| apSigRealmStatsAverageRateOutbound | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.14 |
Average rate of outbound sessions during the period in CPS. |
| apSigRealmStatsMaxBurstRate | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.15 |
Maximum burst rate of traffic measured during the period (combined inbound and outbound). |
| apSigRealmStatsPeriodSeizures | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.16 |
Total number of seizures during the period. |
| apSigRealmStatsPeriodAnswers | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.17 |
Total number of answered sessions during the period. |
| apSigRealmStatsPeriodASR | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.18 |
Answer-to-seizure ratio, expressed as a percentage. For example, a value of 90 represents 90% or .90. |
| apSigRealmStatsAverageLatency | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.19 |
Average observed one-way signaling latency during the period in milliseconds. |
| apSigRealmStatsMaxLatency | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.20 |
Maximum observed one-way signaling latency during the period in milliseconds. |
| apSigRealmStatsMinutesLeft | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.21 |
Number of montly-minutes left in the pool per calendar month for a given realm. |
| apSigRealmStatsMinutesReject | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.22 |
Peg counts of number of rejected calls due to monthly-minutes constraints exceeded. |
| apSigRealmStatsShortSessions | apSigRealmStatsEntry:
1.3.6.1.4.1.9148.3.2.1.2.4.1.23 |
Lifetime number of sessions whose duration was less than the configured short session duration. |
