DTMF for all IWF translations
To use DTMF for all IWF translations:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session-related configurations.
ORACLE(configure)# session-router
Type
iwf-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# iwf-config
From this point, you can configure IWF parameters. To view see all IWF configuration parameters, enter a ? at the system prompt.
Add the telephone-event media profile to the media profiles list and save your work. If you already have a media profiles for the IWF configuration set up and want to keep them (adding telephone-event to the list), then you must type in all of the media profiles that you want to use.
ORACLE(iwf-config)# media-profiles "PCMU telephone-event" ORACLE(iwf-config)# done
