SIP REFER Method Configuration
To enable SIP REFER method call transfer in the realm-config:
In Superuser mode,
type
configure
terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager
and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config and
press Enter.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
- refer-call-transfer—Set to enabled to enable the refer call transfer feature. The default for this parameter is disabled.
Save and activate
your configuration.
To enable SIP REFER method call transfer in the session-agent:
In Superuser mode,
type
configure
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-agent and
press Enter.
ORACLE(media-manager)# session-agent ORACLE(session-agent)#
- Save and activate your configuration.
