SIP Method Tracking Enhancements Configuration To enable or disable the expanded SIP Method statistics tracking: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal Type session-router and press Enter. ORACLE(configure)# session-router Type sip-config and press Enter. ORACLE(session-router)# sip-config extra-method-stats—Enable this parameter if you want to use the expanded SIP Method tracking feature. The default is disabled. The valid values are: enabled | disabled Save and activate your configuration.
