Software-based transcoding alarms and traps
SNMP Traps
The
apSysMgmtGroupTrap trap is sent with the MIB OID
apSysXCodeG729Capacity to alert you of high G.729 Royalty codec usage. This MIB object is defined in
ap-smgmt.mib. It is sent when utilization rises above 95% of licensed capacity. It is cleared when utilization falls below 80% of licensed capacity. The MIB object appears as:
apSysXCodeG729Capacity OBJECT-TYPE
SYNTAX SysMgmtPercentage
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The percentage of licensed G729 transcoding utilization"
::= { apSysMgmtMIBGeneralObjects 35 }
Alarms
The G729 transcoding utilization alarm is triggered when utilization rises above 95% of licensed capacity. It is cleared when utilization falls below 80% of licensed capacity. The alarm appears as follows on the ACLI:
ID Task Severity First Occurred Last Occurred 131159 527739792 6 2011-10-11 10:11:49 2011-10-11 10:11:49 Count Description 1 G729 Transcoding capacity at 97 (over threshold of 95)
Debugging log files
The
log.media log file records host based transcoding events based upon logging level.
