AS Modifier and Headroom Configuration
To enable AS modifier use and establish the percentage of headroom to use:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
media-profile and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# media-profile ORACLE(media-profile)#
sdp-bandwidth—Enable this parameter to use the AS bandwidth modifier in the SDP. The default is
disabled. Valid values are:
enabled | disabled
sdp-rate-limit-headroom—Specify the percentage of headroom to be added while using the AS bandwidth parameter while calculating the
average-rate-limit (rate limit for the RTP flow). The default is
0. The valid range is:
Minimum—0
Maximum—100
- Save and activate your configuration.
