SIP Manipulation Configuration
This section explains the parameters that appear in the subelements for the SIP manipulations configuration. Within the SIP manipulations configuration, you can set up SIP header rules, and within those header rules you can configure element rules.
This section also contains several configuration examples for different applications of the HMR feature.
