PreviousNextJavaScript must be enabled to correctly display this content
UDP Checksum Generation Configuration
To enable UDP checksum generation for a realm:
generate-udp-checksum—Enable this parameter to generate a UDP checksum for this outbound realm. The default is
disabled. Valid values are:
enabled | disabled
This parameter is visible only on Acme Packet 3800s and Acme Packet 4500s that do not have an ETC card installed. The function is enabled and not configurable on all other platforms.
