Network Interface
These are the IPv6-enabled parameters in the network-interface configuration.
| Parameter | Entry Format |
| hostname | <ipv4> | <ipv6> | hostname |
| ip-address | <ipv4> | <ipv6> |
| pri-utility-addr | <ipv4> | <ipv6> |
| sec-utility-addr | <ipv4> | <ipv6> |
| netmask | <ipv4> | <ipv6> |
| gateway | <ipv4> | <ipv6> |
| sec-gateway | <ipv4> | <ipv6> |
| dns-ip-primary | <ipv4> | <ipv6> |
| dns-ip-backup1 | <ipv4> | <ipv6> |
| dns-ip-backup2 | <ipv4> | <ipv6> |
| add-hip-ip | <ipv4> | <ipv6> |
| remove-hip-ip | <ipv4> | <ipv6> |
| add-icmp-ip | <ipv4> | <ipv6> |
| remove-icmp-ip | <ipv4> | <ipv6> |
