suppress100rel Configuration
To suppress the SIP 100rel option tag:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323 ORACLE(h323)#
Type
h323-stacks
and press Enter.
ORACLE(h323)# h323-stacks ORACLE(h323-stack)#
If you are adding support for this feature to a pre-existing H.323 interface (stack), then you must select (using the ACLI select command) the configuration that you want to edit.
options—Set the options parameter by typing
options, a Space, the option name
suppress100rel with a plus sign in front of it, and then press Enter.
ORACLE(h323-stack)# options +suppress100rel
If you type options and then the option value for either of these entries without the plus sign, you will overwrite any previously configured options. In order to append the new option to this configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
