PreviousNextJavaScript must be enabled to correctly display this content
Changes to Action
In releases prior to S-C6.2.0, the sip-manip action is only supported in the header rule (header-rule) configuration. This limitation has been deemed unnecessary, and so you can now set the action parameter to sip-manip at all levels of HMR configuration, including element rules.
