Boot Parameter Changes
You can access and edit boot parameters by using either the ACLI or by interrupting the system boot process.
Changes to boot parameters do not go into effect until you reboot the Oracle® Enterprise Session Border Controller.- directly a part of your LAN for management port 0
- accessible through management port 0
