Import a PKCS #12 File
You can import a PKCS #12 key and certificate file that was generated elsewhere into the Oracle® Enterprise Session Border Controller (E-SBC) by way of the ACLI.
Use the following syntax on the ACLI.
import-certificate <pkcs#12> <Certificate-record-name> [pkcs 12-file-name]
Where
- Certificate-record-name—must be a new name that does not exist as PKCS #12. This is different from other certificate imports, where the certificate record must already exist in the target destination.
- Pkcs12-file-name—the name of the PKCS #12 file that you want to import. Import the file to /opt.
The following example shows the system display when importing a PKCS #12 file named localRecordCert.p12 into the E-SBC.
sd225v# import-certificate pkcs12 localCert localRecordCert.p12
The specified certificate-record (localCert) does not exist
Creating one...
Enter import password:
Certificate imported successfully...
Warning: Configuration changed. run 'save-config' and 'activate-config' commands to commit the changes.
