IWF COLP COLR Configuration
You configure IWF COLP/COLR support in the IWF configuration by setting two options:
- colp-colr-iwf—Setting this option enables support for IWF COLP/COLR
- colp-colr-country-code—Must be set if you configure the
colp-colr-iwf option to recognize or build a national number; the value you enter here:
- Must be a string of digits from 0 to 9
- Cannot exceed 32 digits
- Cannot contain any non-numeric characters; while it allows you to enter them, the system ignores any non-digits characters and so the feature might not work as needed
To enable IWF COLP/COLR support:
