Load Balancing
This section describes Oracle® Enterprise Session Border Controller load balancing. You can use session agent groups to assist in load balancing among session agents. You define concurrent session capacity and rate attributes for each session agent and then define the session agent group. Next, you select the allocation strategy you want applied to achieve the load balancing you want.
The following example shows a configuration for load balancing gateways based on a proportional allocation strategy.
![](img/GUID-09CCB7D0-208F-4AAC-AEB0-E79D5E5E6479-default.gif)
Routing and load balancing capabilities include the following:
- least cost, which includes cost-based and time-based routing
- customer preference
- traffic aggregation
- routing by media (codec) type
- capacity-based, by destination
- service element load balancing
- service element failure detection and re-route
- session agent failure
- routing by codec
