QoS Accounting Configuration
To configure the account configuration and account servers:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
account-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# account-config ORACLE(account-config)#
To configure account server parameters (a subset of the account configuration parameters, type
account-servers and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(account-config)# account-servers ORACLE(account-server)#
The following example shows both the account config and account server parameters.
account-config hostname acctserver1 port 1813 strategy Hunt state enabled max-msg-delay 60 max-wait-failover 100 trans-at-close disabled generate-start OK generate-interim OK Reinvite-Response account-server hostname 192.168.2.2 port 1813 state enabled min-round-trip 100 max-inactivity 100 restart-delay 100 bundle-vsa enabled secret testing NAS-ID acme-accounting last-modified-date 2005-01-15 02:23:42
