PreviousNextJavaScript must be enabled to correctly display this content
Header Manipulation Rules
Header manipulation rules operate on the header you specify when you configure the rule. A header manipulation rule can also be configured with a list of element rules, each of which would specify the actions you want performed for a given element of this header.
