Outbound HMR Challenge
When you use the out-of-dialog setting for an outbound manipulation, the Oracle® Enterprise Session Border Controller only executes this specific SIP header rule only if the same SIP header rule was executed against the initial dialog-creating request.
For example, if the INVITE’s To header was not manipulated, it would not be correct to manipulate the To header in the BYE request. To do so would render the UAC unable to properly match the dialog. And this also means that the outbound manipulation should be carried out against a To, From, or Call-ID header in the BYE request if it was manipulated in the INVITE.
