ACLI Configuration
To configure a session timer profile object:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-timer-profile and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-timer-profile ORACLE(session-timer-profile)#
- name—Enter a name for this session timer profile.
- session-expires—Enter the session timer value in seconds you wish this object to use natively.
- min-se—Enter the minimum session timer value in seconds for this object.
- force-reinvite—Leave the default of enabled for the Oracle® Enterprise Session Border Controller to always use reINVITEs for session refreshes. Set this parameter to disabled for the Oracle® Enterprise Session Border Controller to try using UPDATEs for session refreshes.
- request-refresher—Set this to the value to insert in the refresher parameter in the Session-Expires: header on the originating call leg that the Oracle® Enterprise Session Border Controller includes in the 200 OK response message. Valid values are uac and uas.
- response-refresher—Set this to the value to insert in the refresher parameter in the Session-Expires: header on the terminating call leg that the Oracle® Enterprise Session Border Controller includes in the INVITE message. Valid values are uac, uas, none.
Type
done
to save your work and continue.
To apply a session timer profile to a SIP interface:
Type
session-router
and press Enter.
Type
sip-interface
and press Enter.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
If you are adding this feature to an existing configuration, then you will need to select the configuration you want to edit.
- session-timer-profile—Enter the name of a session timer profile object you have configured and want applied to this SIP interface.
- Type done to save your work and continue.
