PreviousNextJavaScript must be enabled to correctly display this content
Ordering Codecs
Codec policy can specify the order that codecs appear in the SDP offer or answer.
To configure an order which codecs appear in the offer:
order-codecs—Enter the order in which you want codecs to appear in the SDP offer or answer. You can enter them in any of the ways described in the preceding explanation.
