Customizing Lookup Keys
When the next hop parameter points to perform an ENUM or LRT lookup, it can be provisioned with a "key=" attribute in order to specify a parameter other than the username to perform the lookup on. The following table lists the header, key value, and corresponding syntax to configure the Oracle® Enterprise Session Border Controller with.
| Username from Header: | Key Value | Example |
| To-URI | $TO | key=$TO |
| From-URI | $FROM | key=$FROM |
| P-Asserted-Identity | $PAI | key=$PAI |
For a subsequent stage in multistage local policy routing, the lookup key to use for the next stage can be explicitly specified by configuring the next key parameter. By default, multistage lookups use the modified Request-URI returned from the ENUM/LRT response as the to-address key for the next local policy lookup. When the next key parameter is configured, its value will be used for the to-address key in the subsequent local policy lookup regardless if an ENUM or LRT lookup is configured for that policy attribute. The key syntax is for this parameter is the same as with the Routing-based RN and CIC feature.
