SNMP Community Configuration
To configure SNMP communities:
Access the
snmp-community configuration element.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# snmp-community ORACLE(snmp-community)#
- community-name—Set the SNMP community name of an active community where this Oracle® Enterprise Session Border Controller can send or receive SNMP information. A community name value can also be used as a password to provide authentication, thereby limiting the NMSs that have access to this system. With this field, the SNMP agent provides trivial authentication based on the community name that is exchanged in plain text SNMP messages.
access-mode—Set the access level for all NMSs defined within this SNMP community. The access level determines the permissions that other NMS hosts can wield over this
Oracle® Enterprise Session Border Controller. The default is
read-only. The valid values are:
read-only—allows GET requests.
read-write—unsupported.
- ip-addresses—Set one or multiple IPv4 or IPv6 addresses that are valid within this SNMP community. These IP addresses correspond with the address of NMS applications that monitor or configure this Oracle® Enterprise Session Border Controller. Include the addresses of all servers where Element Management Systems are installed.
- Type done to save your configuration.
