Enabling RTCP Latching
To enable RTCP symmetric latching:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
Select the media manager configuration so that you can enable HNT RTCP.
ORACLE(media-manager-config)# select
hnt-rtcp — Enable support of RTCP when the SBC performs HNT. The default value is
disabled. The valid values are:
enabled | disabled
ORACLE(media-manager-config)# hnt-rtcp enabled
- Save your work using either the ACLI save or done command.
