URL Parameter
If the SIP NAT function’s use url parameter field has a value of from-to or all, the SIP NAT function places all cookies generated to hide SIP URIs in a custom tag appended to the header. Setting the use url parameter field to:
- from-to only affects the behavior of the SIP NAT function’s cookies in the From and To headers.
- all affects all SIP headers processed by the SIP NAT function
The cookie is the following:
[;url-parameter]=[host nat tag][encrypted 13-byte host IP][encrypted 13-byte maddr IP]
where:
- [;url-parameter] refers to the SIP NAT function’s parameter name field.
This cookie type is associated with the all and from-to field value options of the SIP NAT function’s use url parameter field.
- [host nat tag] refers to the SIP NAT function’s host NAT tag field.
- [encrypted 13-byte host IP] refers to the host IP encryption.
- [encrypted 13 byte maddr IP (if present)] refers to the maddr IP encryption, if it exists.
With a host NAT tag of ACME- and a parameter name of acme_param, the following SIP-URI:
sip:6175551212@192.168.1.100
might be translated into the following:
sip:6175551212@172.16.1.10;acme_param=ACME-pfi1s7n2pstna.
