PreviousNextJavaScript must be enabled to correctly display this content
Applying a Codec Policy to a Realm
Note that codec policies defined for session agents always take precedence over those defined for realms.
To apply a codec policy to a realm:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter.
ORACLE(configure)# media-manager
Type
realm-config
and press Enter.
ORACLE(media-manager)# realm-config
If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI
select command) the realm that you want to edit.
codec-policy—Enter the name of the codec policy that you want to apply to this realm. By default, this parameter is empty.
