Offerless Bandwidth CAC for SIP Configuration
To configure offerless bandwidth CAC for SIP:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-config
and press Enter. If you are editing a pre-existing configuration, you needs to select it before you can make changes.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
options——Your entry will look like this:
ORACLE(sip-config)# options offerless-bw-media-profiles=PCMU,G729
You can you the plus sign (+) and the minus sign (-) to add and remove values from the options list.
- Type done and continue
