Type
h323-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# h323-configORACLE(h323)#
Type
h323-stacks
ORACLE(h323)# h323-stackORACLE(h323-stack)#
Set the options parameter by typing
options, a Space, the option name
cpnType=x with a plus sign in front of it, and then press Enter.
ORACLE(h323-stack)# options +cpnType=x
If you type
options without the plus sign, you will overwrite any previously configured options. In order to append the new options to the h323-stack’s options list, you must prepend the new option with a plus sign as shown in the previous example.
