Enterprise Software Licensing
A valid license is required for each Oracle® Enterprise Session Border Controller software component that you want to use. To obtain a valid license, you provide the serial number from the system to Oracle and request a license key.
The following guidelines apply to Oracle® Enterprise Session Border Controller software licenses.
- Each license is bound to a specific Oracle® Enterprise Session Border Controller by serial number.
- Oracle does not allow transferring a license from one Oracle® Enterprise Session Border Controller to another.
- The system supports multiple licenses that are active simultaneously on the same Oracle® Enterprise Session Border Controller.
- If a feature is covered by more than one license, the latest expiration date applies.
- The system can activate and deactivate a license in real time.
- A license is fully extensible and upgradable.
- If a component is unlicensed, the system does not display the interface and configuration parameters for the component.
- Software licenses are aggregate. When a new license is added to the original license set, the related capacity, protocol, or interface becomes part of the functionality that you can configure and deploy. For example, if your original license for session capacity is 1,000 and you add a new license for 3,000 sessions, the new total session capacity is 4,000.
For more information, see "Licensing Document" on the Oracle Software Delivery Cloud website in the directory with the software image download file.
