SSH Remote Connections
For increased security, you can connect to your Oracle® Enterprise Session Border Controller using SSH. An SSH client is required for this type of connection.
The Oracle® Enterprise Session Border Controller supports five concurrent SSH and/or SFTP sessions.
There are two ways to use SSH to connect to your Oracle® Enterprise Session Border Controller. The first works the way a Telnet connection works, except that authentication takes place before the connection to the Oracle® Enterprise Session Border Controller is made. The second requires that you set an additional password.
To initiate an SSH connection to the
Oracle® Enterprise Session Border Controller without specifying users and SSH user passwords:
Oracle® Enterprise Session Border Controller with an SSH username and password:
